Throwout bearing/input shaft bearing noise
Wichita, KS, USA
Was wondering if anyone has ever replaced the throw out bearing/input shaft bearing/s on their car as I'm suspecting either one or the other is going out on me. Not sure exactly what part I would need (part number wise for input shaft bearing/s) and if anyone has some insight on this that would be greatly appreciated. Thanks.
MagnetiseST
Dania Beach
The throw out bearing is part of the clutch slave assembly. The part number is: DG9Z-7A564-B
The input shaft bearings, however, are much harder to come by. Ford does not service many of the internal parts to the transmissions in the US, instead you must replace the whole unit. You should be able to find the part numbers and where to buy them here: http://blog.sluggyjunx.com/files/2019/11/Ford-Fiesta-ST-Transmission-Parts-List-and-Notes.pdf
or browse his entire page on his transmission rebuild here: http://blog.sluggyjunx.com/rebuilding-the-transmission-in-my-2014-ford-fiesta-st/
IIRC you also need a very heavy press to get the gears off to replace
