Thoughts on Rustproof/Undercoating ?
Buffalo
Hello everyone I live in Buffalo NY area which we get depressing amount of snow which results in significant amount of salt as well. Wanted to see what people's thoughts on undercoating/rustproofing for our fists.
Y
Buffalo
Spoke to a guy that does that and he says he drills holes into the panel. is it something that I should be worried about
south shore, montreal
Personnaly I dont like to drill hole over the year those hole do rust even with the plug. You put the antirust trought the drain hole in the door and the fist rocker panel already have big Rubber plug underneath the car. If you really want à top notch job remove the door panel and remove the trunk side plastic panel so you can shoot antirust between the rear wheel panel and rear body.
Y
Buffalo
Oh man. Decisions decisions
Wetaskiwin
Had mine done when I bought it.I don't drive my baby in the winter but if she rusts Ford will have to cover it.
KKaWing
Somewhere
Just a note, the rustproofing spray also protects the wiring connectors as well. I don't believe the person that did my car needed to drill any holes. If they did, it looks OEM...
atlanta
Fluid Film offers good winter protection though it requires re-application unlike those rubberized undercoat that will last longer.
