Thinking outside the box 😎
Old Mike Emerson
U.S. Navy Veteran
Uniontown, OH, USA
As I have been doing nothing but watching YouTube Fist builds and reviews and looking at parts, I have been thinking a lot which is a bad thing LOL! I was on e-bay and found an intake for the non-turbo 1.6, it uses the same intake gasket so that tells me it at least will bolt on. Looking closer I noticed that it also has fuel injection ports, thinking auxiliary fueling here. The question I have is has anyone else tried using this intake on a turbo car?
Keyport
I'm definitely a little confused. The none turbo 1.6 intake is completely different. It goes to the front of the engine and is substantially shorter.
Sent from my KB2007 using Tapatalk
Keyport
Are you referring to the intake manifold? If so I honestly don't think that would work or fit
Old Mike Emerson
Old Mike Emerson
U.S. Navy Veteran
Uniontown, OH, USA
Still researching, if you see the intakes side by side they look different but mount the same, at least it looks that way, will know for sure when I have them both in my hand and measure them.
Saint Pauly
Stratified designed a 4 port Aux fuel system with Peron to soon follow with their own design a couple years ago.
Old Mike Emerson
Old Mike Emerson
U.S. Navy Veteran
Uniontown, OH, USA
Not done with this idea yet, need to get the different intakes on the bench. I never give up on the first go around. LOL. By the way I did find out that the 2.3 eco Mustang TB which is 65mm, is a plug and play fit on the Fiesta ST which has a 52mm TB, Fiesta 1.6 NA motor, Focus ST which has a 57mm TB. Saw it installed, and driven, no dyno numbers at this time.
