This v-dyno shows the difference between the stock tune (with Woosh FMIC), and an E30 tune by Adam (Tune+).
The car is a 2017 ST with stock intake with stock paper element, stock downpipe, stock turbo, MAPerormance catback, Woosh FMIC with stock piping. Car has 2900 miles on it.
I'm running E30 in the tank. The "E85" here in southern Arizona tested out at E55.
These pulls are at about 4500' above sea level. I know that the actual numbers are a ways off vs what a real Dyno would show, but the difference between the two pulls is significant, and the power curve is so much better. ***Edited*** I just noticed that I had the settings in vdyno set at custom 1.25. I'll repost with it set at Dyno jet.
This is also the initial E30 map sent to me by Adam. I'm sure there will be some tweaks in the revisions.
There were no negative timing corrections, and no knock (even when loading it up in 4th, and 5th gears.
