SWAVE Summit Chassis Handling Products available in the USA @ whoosh
kivnul
U.S. Army Veteran
Deer Park, WA
The back one that has six points is the one I have my eye on.
Looks like it is not compatible with the Pierce 4 point. I made a bastardized image to show
The two center bolts are directly under the pierce bar.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #25
How much you are charging for the chassis braces?
we're loading all the product range this week
whoosh will be offering SWAVE's full range for the Fiesta, Focus ST/RS and Mustang so there is quite a bit of product to cover.
I'll prioritize Fiesta as usual though haha
Newberg
Sweet can’t wait to drop some tax money on the fist! Lol
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #28
How will they fit with the Hotside pipe that is non factory or ATP?
I'll test with cp-e / Mishimoto being 2.5"
ATP, whoosh, MBRP, Peron, Turbo Technics all use OEM size (1.75") or 2" pipework which clears no issue
Sekred
Mid North Coast
I am using a EFR turbo (Peron kit). I had to modify the mounting for the hot side charge pipe. What I did was remove the studs where the pipe bolts to the rear of the sump and use bolts. This raises the pipe about 1/4" of an inch. I also bent the bracket on the charge pipe to raise it a little further. This involved cutting part of the bracket and bracing it.
Look at the image I posted before get some idea of what I mean.
Colorado
#37
Getting antsy - how much clearance does this gain say over similar products from TB?
If it's negligible, I'll likely go with the cheaper TB Perf products as I know SWAVE is pretty proud of their products.
#39
I was considering both and the design of the TB 4 point kind of leaves me wanting. The SWAVE is better. The problem with SWAVE is they are really hard to nail down and deal with even UK shops a lot supposedly stocking according to SWAVE do not have product in stock. I would probably have one now otherwise.
Meridian, ID, USA
#40
I am hoping for the Woosh version Ron will materialize before swave ships. You know he will eventually have a Woosh engine block in the works. :)
