Through asking questions and getting answers from Jerrick at Meister R, I concluded I don't know jack about springs and dampers. Thought I did.
Understanding your Dampers: A guide from Jim Kasprzak is a 25 page white paper on springs and damping I have read several times and need to read more. The most illuminating point to me is that diagnosing a bad damper on a car is nearly impossible. If true, we could all be driving around on bad dampers and not know it.
Main point is that many of us desire better cornering performance on track. Lowering springs and coil overs offer ways to lower COG. Higher spring rates than stock are generally considered good for track by reducing weight transfer to outside wheels, ie reducing roll in corners. Higher spring rates are not as good for street. But those of us fortunate to have mostly good roads can get away with a little more stiffness on road for improvements on track.
Somehow dampers get left to the last item of interest. There used to be a section on Far North Racing web site on dampers, basically said most are junk. Claimed most dampers regardless of cost will not dyno match each other when brand new, much less after track abuse.
I am willing to do the calculations required to get into the ballpark on sprung and unsprung frequency, get to a spring rate # for F & R that seems about right for tracking our cars. From a practical perspective, Joe at 2J has already opined 6/4 or 6/5 F/R is the sweet spot for combination road and track springs. Members of this forum have reported those spring rates are a good track compromise. RAAM is trying out even stiffer combos, my words from his comments are that going higher than Joe recommends will get sketchy on bad roads.
But what to do about dampers? Does anyone dyno their dampers to find out how they behave?
