Suspension and Bushing Refresh
Summerville
I'm coming up to ~100k miles and was looking to refresh some suspension and bushings. I'm looking for any input on things I should update while I'm in there. I have a distinct clunk while backing out the driveway that I'd like to address (full lock). I don't mind some NVH but I'd like to keep it close to stock (CPE rear motor mount was too much for me). I'd say the main goal is for future reliability without losing the character of the car. Any input is appreciated.
Current plans:
Replace stock shocks with B8's paired with previously installed mountune springs
New reusable lower strut bolt set
Replacing stock driver/pass side motor mounts with powerflex bushings
Camden, NJ, USA
if you are looking at a "set it and forget it" parts, power flex inserts ARE NOT the way to go. they're kinda meant as a sacrificial wear item that might disintegrate at the wrong time. At best, it'll wear and you'll need to replace it down the road and it's something you're supposed to check periodically.
most people here (including me) would recommend vibratechnics softest mounts as a great OEM upgrade.
FlordPerformance
U.S. Coast Guard Veteran
North Eastern USA
Only thing I can add to this is that if you're going to be replacing the rubber bushing with Polys, you'll need non-petroleum grease to maintain these and if you're anywhere near the sway bar bushings.. best add teflon tape to the sway bar at the bushing contact point.. otherwise you're going to hear some squeaking.
XanRules
Portland
I haven't heard or experienced this on the powerflex inserts, but good to know.
felopr
JD
me looking at my powerflex rear motor mount inserts with 50k miles looking great...
forevercasual
Summerville
I haven't heard that about the powerflex inserts either, but I'll see what I can find.
forevercasual
Summerville
Anyone have any input on whether there are other bushings that would tend to become sloppy at this point and should be replaced as a maintenance item?
FlordPerformance
North Eastern USA
Control arm bushings but it would be cheaper to just replace the entire control arm, sway bar bushings and don't forget to replace the rubber/poly isolators within the strut and replace the top strut mount. You may need to check the trans mounts also. I would also address the end links as the ball joints or bushing in these could be shot. We spent nearly 7K on replacing all the items listed above on our 2020 Connect. So be prepared if you're going to get this deep it will cost using performance parts and sometime you have to make exceptions to the rule and use OE
XanRules
Portland
Yeah, I just went out and looked at my motor mounts - the rear is a Cobb and the two side motor mounts are Powerflex, all look brand new at almost 80k miles. Not going to worry about it.
green_henry
Pleasant Hill, CA
I haven't had any issues with the driver side Powerflex isolator or the rear spring isolators, but the passenger side 'pineapple' wasn't reliable. The o-ring snapped after a few sessions at the track. If it's only for daily driving duties, it's probably fine.
