Hi,
I own a 2013 Fiesta ST MK7 with 75.000 KM / 46.000 Miles on the road. During these last 6 months I've been getting steadily increasing grinding noises from my front end. The grinding used to only occur during high speed bumpy left turns. As time went the noise started to appear during slower speeds. Today I can barely drive in the speed limit and I will get this terrible noise during left hand turns or when going down bumpy Norwegian roads. I can't even use boost in a straight line when in 6th gear without this noise.
At first I thought it was the transmissions as it only happened when doing high gear high load left turns. Recently this has started to happen regardless of gear selection. If I accelerate even somewhat hard while making a left turn, I will get this noise as long as I'm driving over 60 KMh or 40 MPh. It is even more evident when going down hill. Or over bumpy tarmac roads.
I've tried to make a recording of the noise so you guys could check it out.
Link: https://clyp.it/gh3heiy0?token=3404a4f7cc4e9e22dada216f13b4d1dd
Has anyone else experienced something similar? I'm not sure where to start with troubleshooting this.
Hiring a mechanic by the hour for troubleshooting is very expensive where I live. Any clues that could help me narrow this down would be greatly appreciated.
