Dialcaliper said:
Iām kind of wondering if some of your rotation issues stem from, wait for itā¦not enough front roll stiffnessā¦ specifically, the effect that front roll has on your splitter. Your front springs are more than stiff enough, but springs alone donāt control roll very well on this platform - you mentioned that disconnected your front sway bar.
Two different setups. When I ran Gridlife back in June, I was running 250/250 with 21mm Eibach rear bar, same alignment and Little Wang, splitter was 3in long and 4in off the deck. By the end of the weekend I was out of spring rubbers and resorted to disconnecting the front bar to try and get the car looser. 250lb front springs the car just flops over on that corner, its pretty terrible for track work.
Last event was 5in splitter 3in off the deck, 450/550, 21mm rear bar, stock Front bar connected, same wang, just dialed down 2 deg.
On a strut car, springs will work fine for controlling front roll stiffness, they also don't have the inherent compromises of big sway bars on inside tire lift, thus making the front wheel spin on corner exit.
I am also not running the car that low, its basically stock ride height.
Dialcaliper said:
If your splitter is at too steep an angle across the front of the car, youāll leak air on the inside and choke flow to the outside as it scrapes the track, and lose some of your downforce in the front, leading to a push. If this is the case, simply adding massive rear stiffness to the the rear will just kill rear grip as well and slow you down.
The car doesn't "push" as far as a normal person is concerned, its just not as free as I would like. Its not an aero push as the car is fairly neutral when I over cooked it into turn 1. Was surprised it didn't get backwards, but I just laid on the throttle and thats probably what pulled it out straight.
Dialcaliper said:
This will be especially the case at speed, and I noticed you mentioned trimming out the rear wing to zero in an attempt to fix it, which leads me to believe you were seeing it more at higher speed. Also if you recently lowered your splitter, it will become even more sensitive to this sort of ride height variation.
Again, if the car were "freeer" in the slower speed stuff I suspect the high speed is fine. Wing tuning saved me crawling around under the car in 100deg paddock temps. Need to hit RA or NCM to see how it behaves though. My Little Wang is no where near as big as most people's. Its 48in long. I thanks Woods24/7s Big Wang is 72in wide. He has a lot more rear down force.
Dialcaliper said:
Not trying to dissuade you from the sway bar path, but just tossing out some other things to think about, and going back to the ālow speed=suspension, high speed=aeroā for tuning out understeer/oversteer issues
If it don't work, I can cut the bends up and will have some spare 4140. In my past experience, a big bar makes a FWD work better than any other setup. I typically run huge bars on all my race cars and they work well. I built a 1.75x.095 diameter rear bar for an Acura CL, think I have a 1.25 x.095 on my Integras, etc. The bigger the better, within reason.
