Stage 1, 2, 3, 4, 5 audio upgrade suggestions
antarctica24
O'Fallon, MO, USA
A forum member asked me to put this together, so here it goes.
I was able to listen to another ST today. It was a Focus, but that really doesn't matter because everything was upgraded. The breakdown included, grabbing the tweeter and midrange and sub wires and summing into a Mosconi 6to9 processor. He has Focal speakers up front and a JL Audio W13 in the trunk. No rear speakers. Amps are JL Audio.
The Mosconi piece is a little different in that it has an input EQ and an output EQ. So when you hook it up, you run an RTA pink noise sweep, make corrections to the factory stuff, then use my instructions for the rest of the tuning.
I have listened to this vehicle with my material many times and today, the sky opened up and provided me with some much needed information regarding the performance of the Ford system.
In another post, I brought up a new piece of software which is available on both Android and Iphone, Ipad called Teac HR Player and gave instructions on how to set it up. A lot has happened since I made that post this morning. I went back to the audioshop to listen to his vehicle again with this player.
Test 1: Direct hook up of my iphone to his vehicle through FORD USB port. Played several tracks using ITunes.
Test 2: Same setup, but this time, used Teac HR Player.
I have said in a previous post, on a scale of 1 to 10, the FORD system is a solid 1 maybe a 2. And as the strength in any chain is always only as good as it weakest link, His system sounds good, not as good as it could, but it is a solid 6.5. And for me to give that rating is rare. When I do critical listening, I do it as if I were judging the vehicle.
Test 2, easily took his system to a 7.5. The difference between the two was very audible, taking his over all music quality to a 7.5.
Test 3, The Mosconi has a unique Bluetooth board that allows you to connect your wireless device directly through Bluetooth bypassing the Ford System.
Wait for it, hear it comes, NIGHT AND DAY. Easily a solid 8.5 in tonality out of 10, maybe an 8.8. I could not believe what I was hearing. Now here is the stupid part, Crap in is crap out. We were listening to AAC files converted into ITunes being upsampled to DSD 5.6Mhz. Which honestly should not have made any difference, but as I said before, you could hear the difference on my factory speakers, and in listening to this in my car, you could really start to hear the limitations of the Ford Factory Speakers.
So lets begin.
STAGE 1 AUDIO UPGRADES:
TEAC HR PLAYER. PERIOD. Use the instructions I put in the other post, "Come out of the cave and step into the light"
CD's are recorded at 44.1khz. DSD is recorded at 2.8mhz, 5.6mhz, and 11mhz. LIGHT YEARS AHEAD OF CD. These files were SACD files or Super Audio CD.
COST, not a lot.
Many may here this and decide they are done, it was that good. If you listen to online music like Pandora or spotify, there is another option You can buy a OPPO Portable DAC. You plug your lightening port into the DAC or with a special cable your android into the DAC, then use the line out and plug it into the FORD 3.5mm jack in the armrest. You still use the TEAC player for recorded stuff and now your Pandora stuff will sound good as well. The DAC sells for $299.00.
STAGE 2 AUDIO UPGRADES:
This is addition of sub, and small amp. Not a lot of tuning required here, amp should probably have a volume knob for adjusting the level of the sub at the amp and you can mount it upfront so you can adjust it on the fly. The amp will also have or need a built in crossover. Price for this upgrade varies a lot on the amp and sub. There are lots of 100 watt amps, that will more than power a 10" sub in this vehicle. Remember there is no truck to block anything. And to be quite honest if you don't want to spend a whole lot of money, don't. Any 100 watts amp, and most 10" subs will suffice with what you are trying to accomplish.
STAGE 3 AUDIO UPGRADES:
Speaker replacement. This is very subjective subject matter. Everyone has different wallets, everyone had different ears, and different tastes. What I can tell you from judging over 1000 cars, and listening to some of the best stuff ever created from all over the world. The best sounding speakers come from Germany, Norway, Sweden, Denmark, Israel and Italy. The French have no business making speakers. Sorry. My Opinion. The Germany made speakers 9 out of 10, always sound so nice.
As I stated in my tuning post, you do this upgrade with risk, if you do it with the factory amp. The factory amp is not a 4 ohm amp. It is something like a 8 or 10 ohm amp. When you put a 4 ohm driver on this amp, you are creating a load that the amp was not designed to work with and you will burn it up.
So, with this upgrade should come an external amp. A sub is not necessary but it sound nice, so a 5 channel amp will work. If you want to keep the back speakers, you get a set of components up front, this is a tweeter, and midrange(more than likely a 6.5"), 6.5" for the rear doors, and a sub. You can use a passive crossover for the front, that is for Channel 1 and 2 on the amp, Each rear door speaker gets a channel 3 and 4, and the sub gets channel 5 unless you like a lot of bass and want two subs, and then you can just wire the sub in parallel or series depending on what the amp will allow.
I also have stated, replacing the speakers, changes the tune, which would mean you need someway to tune the system, however there is another option.
JL Audio makes a piece called the FIX82. What it does, is remove the tune from the factory radio and get you back to flat unturned. You then just send the RCS's to the amp, and your good to go. No processor necessary. It will not sound as good as it could unturned, but it will work if you don't want to go that far.
Picking out speakers is a bit of a challenge, because nothing will sound right on a sound board compared to how it will sound in the car. There are those who pick their speakers based on specs called Thiele Parameters. Specs are good and tell a very specific story, but I have also found that some experience and special fabrication of the speaker enclosure, and send the parameters out the window.
Metal dome tweeters are normally too bright. They create a lot of sibilance. Lots of SSSSSS sound. Yes you can tune it down, but if you have to tune it down to make it sound better, it was not the right speaker to begin with. Silk is another variety and a favorite of mine. Silk is never too bright and is soft. No it will not play to 32,000 kHz, but you cant hear that high so move past it. Normally humans can only hear up to about 17K. As you get older this gets worse. Everything above that makes the audio sound airy.
Woofer material works likes this. The lighter the material, the faster the speaker, the better it will sound. Images will be tighter. The slower the speaker the fatter the images. This rule has never failed. ever. A cone needs to be light and stiff. Light for speed, stiffness for less distortion. If you put a speaker in your hand, put your fingers underneath the basket lifting up on the cone from underneath but above the spyder assembly (The wavy looking piece), and lift with two fingers on one side of what you are holding. If the entire cone moves at the same time rising. YOU HAVE YOUR SPEAKER. If the cone goes lopsided, PUT IT BACK. Another very important aspect of speaker selection is Voice Coil size. This is a papertowel spool wrapped( you know the cardboard tube) in copper, silver, or aluminum wire. The bigger the spool, the more power handling capabilities the speaker will have. Copper will be cheaper than silver, and Silver will be cheaper than Aluminum. What the basket is made out of matters too. Plastic is better than metal. Why? Because as the speaker is vibrating, it will create its own resonance and the basket will resonate. When it does, if you hear it, which you will, you have now added something to the music that wasn't there. So why do companies do that? Because of cost. A typical speaker of any quality cost about $50.00 to make in a one off scenario. How do I know that? Because I have had some made for special circumstances.
Subs are all about excursion (how far the cone will extend beyond its resting position), power handling, and that is about it. Some do it better than others, and JL Audio would have you believe their W7 is an engineering feat. Yeah Yeah Yeah. Subs also don't make their own power. So please do not describe your sub as "I have a 1200 watt wanna be sub". Just state the size, and everyone will get where your coming from. And if you think you bought an amp that is generating 1200 watts. So if that is what your amps says, take the total number of watts and divide that by volts. In this case, 1200/12. That would be 100 amps. There should be a 100 amp fuse in your amp. If there is not, then it is not a 1200 watt amp. Then there is the whole problem of powering such a thing on an alternator that is only 115amp.
So here are my choices. Pioneer (This is not a country I had listed, but and however, this is the best brand for the money). You will not find a better sounding speaker for less money anywhere on planet earth. PERIOD. I have judged plenty of cars, with all Pioneer Systems, and the systems were exceptional. Audison, Diamond, Morel, Scan-Speak, Dynaudio, SEAS, Helix, again, I am a audio snob, remember. There are many many other brands that sound great, but these would be my go to brands.
For the record let me be specific, I could load up a Fiesta ST with speakers from Radio Shack and a processor and I could make it one of the best sounding systems you had ever heard. What it comes down to is, how much tuning did I have to do to get there.
For the most part, you really get what you pay for, but Pioneer is an exception. Very nice silk tweeters, and very fast midrange drivers.
AMP Selection
I know I said any old amp will do with the sub, and that is true. But it is not the whole store. How much you can make the amp use its useable power makes a difference in how it sounds. When selecting an amp for your tweeter and midranges and midbass, makes a big difference. I used to play my amps at about 75% volume with pink noise to get them hot before a judge would listen to my car. Electronics just work better that way when making sound. Most amps you come into contact with will have a CES rating on their power. This is their real power rating at 12 volts and 14.4 volts. So with a 100 watt amps, 14.4 would give you 100 watts, and 12 would give you something like 75. Then there is signal voltage. This is how much voltage is coming across the RCA. The input stage of the amp cannot take more than what it is rated at. So if you are looking at an amp with a 4 volt signal rating, you want your head unit, to be 4 volts. The better choice is a amp that will take 8 volts, and a head unit that could put out 8 volts. They don't make them anymore, but man. More signal voltage is better. Just trust me.
STAGE 4 AUDIO UPGRADE
This is a 4 way setup
This consist of a dedicated tweeter, midrange, midbass, and subbass speakers. Generally it is 8 speakers 4 per side, each speaker having dedicated amp channels, and a processor for tuning. Setting this up is extensive, and it is not about just installing the speakers in the car. This requires planning, sound deadening, custom wiring, fabrication for subboxes. Etc. Anyone wanting to do this in their car, I am more than happy to help them out in planning the system. This is what I am getting ready to do in mine and I will share every aspect of what I do, so anyone who is interested can follow.
After a long and hard consideration and money was no object here, I went with Morel MW4 hybrid midranges (There will be 2 4" speakers on each side of the dash), and I went with Morel Titanium Hybrid 6.5" midbass drivers. These speakers were chosen because of their history, and the power handling capabilities. You can buy without listening to any speaker from the countries I listed without any hesitation that they will sound good. These are from Israel. Think Finger of GOD manufactured by Jesus. I couldn't resist. My tweeters that I want are pricey. They are $549.00 per set. They are Scan Speak and used for the home environment but are 4 ohm like my amps which are Alpine PDX V9's. Subs are more than likely going to be A/D/S which does not exist anymore. But stay tuned.
STAGE 5 AUDIO UPGRADE
This is where you get anal. Building sealed enclosures in the door for midbass drivers (You will see what I mean), Custom making your RCA wires from cryogenically treated cable (Us audio snobs believe it makes a difference, so as long as we know it was done that is all that matters). Single strand speaker wire instead of multi-strand (think of the bandwidth capabilities of coax). Multi-strand was invented to make installation easier because it is flexible. Using exotic materials to make your sub-Box, A lot of people like Birch, But trust me there are a lot of better materials. THIS IS A TRADE SECRET SO SORRY CANT SHARE YET. Printed speaker enclosures for the dash for the midrange and tweeter. Using High end DAC's for processing music. These are all the things that give you that little extra 10-15% of sound quality. When you are competing against others, it is necessary, but when you are competing against yourself, it is twice as important. I am building this car to challenge what I did in my Fiero. Only time will tell.
I hope this helps, If anyone has any questions or needs some assistance, let me know.
One more word of advice, I said at the beginning of stage 3, that everyone has a different set of ears and different taste. But one thing to note here, when I was judging at sound quality events. I was not the only judge listening when were going around doing cars. 100% of the time, judges would remember specific aspects of different cars, but the odd thing was every judge remembered the same thing. Good Sound is subjective. Great sound is not and neither is finger of GOD Sound. When you hear it, you know. I remember every car that I heard that stood out and so does every other judge about the same exact cars.
Jims_ST
Sydney
Hi Antarctica, thanks for your useful insights so far. I am wondering about your note to be careful with using aftermarket speakers with the factory amp.. There are a few used fiesta ST speakers for sale on eBay which indicate that they are 4ohm speakers in the stock ST. Therefore is it correct to assume there should be no issues with overheating of the stock amp, on replacing the factory speakers with other 4ohm speakers?
Cheers
Peoria
HUGE disclaimer: I know nothing other than I'd like some small improvement in sound quality in my car. But I have a (number of) question(s). First, are you using Apple's CarPlay in all of this? Thanks.
antarctica24
antarctica24
O'Fallon, MO, USA
I'm not but you can tell me what your wanting to do and I'll help you out.
Peoria
So you have your music on your phone and don't use the radio, etc.? I like to listen to the local airwaves, a couple of podcasts, and will be getting some of my music collection into the car one way or another (phone, usb flash drive, disc, etc.). I'm guessing the TEAC HR Player doesn't work in the CarPlay interface.
What year is your FiST? I don't think I have a 3.5mm jack in my '16 model for the OPPO DAC.
If I'm reading what you've posted correctly, iTunes through USB sucks, Teac HR Player through USB is better, OPPO DAC for streaming is as good as TEAC HR Player or better, then the Mosconi.
My Google search can't find a Mosconi 6to9 Processor, but finds a Mosconi 6to8 Processor - is there a difference (also, it only seems to be overseas from the U.S.)?
The Mosconi connects to the speaker wiring how?
the speaker replacement, amp, and sub are straightforward, thanks.
antarctica24
antarctica24
O'Fallon, MO, USA
Ok lets see if I can help here, My Fist is 2014.
First its the 6 to 8 and Aerospace processors. http://mosconi-america.com/
If you had the 3.5.. jack it would be in the in center console. Anything compressed in your words sucks. The teac player upscales the music, and it makes a big difference in the way a ITunes or MP3 sounds. So the Teac is an upgrade for iTunes as you would have it. For the DAC, it is all in the converter or Analog to Digital Converter. So the first issue with the OPPO is the voltage out. If your not getting at least 4 volts, your missing out, right? As for Quality, you are either a fan of the Sabre Dac or not. I like the AKM dac. But that is neither here nor there. The oppo is not going to perform better than the Mosconi piece for no other reason than the power supply and the dacs in the Mosconi pieces are much better. That is an industry opinion not mine. Im not dissing on the Oppo piece. I almost bought one, but the voltage out was not enough.
If comparing the Oppo Dac to the Teac player, your oppo dac wins. If comparing ITunes or MP3 to Teac Teac wins. If you get a DSD file and run it through your Oppo which is supports, You are on cloud 41. DAC's are funny creatures. The converter, the digital clock correction, and power supply, all control the quality of the DAC. Some are closer in relation to each other than others. AKM is newer than most, but it is getting a lot of praise. Analog Devices some good some not so good. Burr Brown which I am sure you have heard of, the ESS Sabre in the Opp, and Wolfson.
This is your daddy DAC
http://www.msbtechnology.com/dacs/reference-features/
I consider these people to be the Finger of GOD people when it comes to DAC's. When I had my ODR piece, the RS-P50 from Pioneer. I got them the schematic to the processor, and went it and changed the input stage to accept 10 volts of signal, upgraded all of the input and output stage caps, and the DAC. I spent $4K having the piece modified. At the finals when I was competing Expert, the VP of Engineering from Pioneer came over, to listen to the car because at that time I was being sponsored by Pioneer. He sat in the car for an 2 hours, and when he got out he wanted to know what I had done. He asked me when the show was over could he buy the piece from me. At the time I told him no, but that at the end of the season I would contact him. They paid me the $4K I had invested in the piece.
While I would never invest $39K in a DAC for the car, I would easily buy the $7K version.
This is the one I bought
xDuoo XD-05 32bit/384KHz DSD DAC Portable Audio Headphone Amplifier (Black)
because it has the AKM dac.
The mosconi has a high level and low level input. You can use the Mosconi 6-8 without the JL Audio piece because it has a Input EQ as well as output EQ. The difference is with the JL audio piece, you put a disc in and run the disc and the JL piece will listen to the signal and make all of the corrections to bring the signal back to flat. With the mosconi piece, you would use an RTA, like the audio control piece or one you buy on your phone (less sensitive, but will do the job), so you make your adjustments on the input EQ to make the system flat, then retune to account for the acoustics of the car and new speakers.
As for replacing the door speakers. Straight forward somewhat. I am not a fan of factory wiring. However, if you choose to use factory wiring, then replacing the door speakers is a no brainer. If you want to use aftermarket wire, you have to make modifications to the molex plug in the door.
albuquerque
This is great! I've installed at least a dozen car stereos in my life, yet this went right over my head! I've had my Fiesta since November and am certainly not impressed with the stock sound system. At some point I plan on tackling this car, adding amp, subwoofer, and upgrading the speakers.
The thing I'm not sure about is taking the factory DACs out of the picture while still being able to navigate the system as usual. Would the oppo/mosconi or similar unit be installed take signal from the head unit? I'm a little confused on the chain, actually.
Say I'm playing something from Spotify off my phone through CarPlay. Is the head unit going to send an unconverted signal to the oppo/mosconi? Does the oppo send signal directly to the amp?
What the magic with the TEAC player? Are you saying there will be a big sound improvement if I listen to music via that app through USB? Or 1/8" headphone jack?
antarctica24
antarctica24
O'Fallon, MO, USA
Thread Starter #12
Ok, a couple of things first. The DAC in the Sony piece, there is no getting around that, if you are playing the radio or CD, Sort of.
The only way to keep the factory controls is to use analog connections from the factory head unit to the processor. But once you get to the processor, there is a two step conversion that goes from Analog to Digital, PROCESS, then from Digital to Analog. So no matter what you get to use the DAC that comes with the processor. To step that up, You have to use either the JL audio piece the Fix 82, which is analog into the fix 82 from the factory speaker wires, then it has a toslink connection that can get you to a myrid of processors. But In doing this you lose the factory steering wheel controls.
To use your Oppo, the best method is to use the Mosconi, run the speaker wires from the factory head into the mosconi, and then plug your phone into the oppo and the oppo into the aux input of the mosconi.
Now, with all of that said. I need to make some stipulations. Standard audio on a CD is recorded at 44.1Mhz 16 bit audio for Red Book Standards. Anything above 16 bit is corrective up to 24 bit the oversampling in the CD mechanism rereads the disc and uses the number of bits above 16 to correct clocking errors to reproduce 20hertz to 20,000hertz.
It is funny to note that you can buy a record player that will do the exact same thing without the clocking errors. Moving on......
24bit and 32bit are DSD level recordings. Another word for DSD is SACD or Super Audio recordings. Same format. There is physically more information there to be read. These recordings have more detail, are louder, and have more impact amongst other things. Think of the difference between a DVD and BluRay. Not the same technology but you get the meaning of what I am saying.
If you have an iTunes recording, what is happening is the song is compressed using an algorithm. Most importantly, and you can see this on any digital spectra graph, is ITunes is removing a lot of information from the recording about 17K. The higher the frequency the more information. That is how a majority of the space is saved, and as we struggle to perceive above 16K let alone hear it, we perceive that there is nothing missing, and in fact our brains end up making most of the correction, especially if we have heard the song before. Want to put that to the test? Take a song that you really know the words to, turn the radio on while your going down the road, windows down, you can hear something on the radio, but cant quite make it out. So you turn up the volume figure it out and then turn it back down, Now for some reason you can clearly hear the song and can follow along with it.
Small diversion for a moment....Tuning a vehicle works the same way. You can only sit and tune a car for about 20 minutes at a time. Why? Because your brain starts to make corrections without telling you, so you end up hearing stuff that isn't there. That's why you have to get out of the car, and come back later. These people that say they stayed up all night tuning their car. BIG MISTAKE. Anyway
If you spent the money on the Oppo Dac, thinking you would improve the situation by running the iTunes stuff through it, you can, but it was a waste. What you want to use that DAC for is to take a CD, run it through the factory system, into the JL Audio Fix 82, come fiber out of that into the Oppo piece then analog out into the aux input of the mosconi piece. This would give you the absolute best sound possible.
option 2, would be come out of factory head unit into mosconi piece with factory speaker wires. Then come out of phone into Oppo piece, then to AUX input on mosconi piece. Pretty sure you could still control volume through steering wheel controls. But, you need to store songs on your phone in WAV format not ITunes format.
The magic of the TEAC player, is it is a DSD player for your phone. Most DSD converted songs are like a gigabyte in size. But, the TEAC player will take a ITunes, flac, AIFF, WAV song and upconvert to DSD while playing. I have made the argument many times that you cannot get something out of something if it was not there to begin with, but whatever the TEAC Player is doing in the conversion it make a big difference in the output. Enough to get my attention. My quest started with getting all of my music in the car. The first system I competed with had 4 12 disc changers. Today with Terabyte harddrives, and tablets the technology exist to allow me to load my music onto a portable multiterabyte drive with songs in WAV format, and control them through a Windows Tablet, coming out of the tablet into the AUX input of the Alpine head unit, thus why I picked that head unit.
another nice feature of the Mosconi piece is you can buy a Dedicated Blutooth adapter that plugs into the Mosconi processor, and can connect directly with the blutooth from the phone. It is a much better connection if you have to go wireless.
1/8 jack is analog. USB is digital.
PM me your phone number, and I will call you and I will walk you through it.
Calgary
Very interesting points.. I will try the teac player as well this weekend.
I also didn't know about tuning for 20 minutes at a time!
I remember in another thread that the weight of the actual sub/cone has to do with the speed? I have an enclosed 2x 10" box in the back, I think I need to replace the subs to something lighter.. its a JL box
antarctica24
antarctica24
O'Fallon, MO, USA
Thread Starter #14
Speaker design is very odd in the way that it works. I had mentioned the weight issue because with a midrange it is everything. That's why a 6.5" is not as good as a 5.25" and a 5.25" is not as good as a 4". But there are tradeoffs. The 4" is obviously not going to reproduce good midbass. The 5.25 depending on the design can come close. That's why people use a 6.5 in a 2 way setup. They get midrange and midbass frequencies covered. The 3 way in my opinion is better, but is much harder to tune, you get a smaller midrange driver. The 4 way, is the tweeters midrange midbass and subbass. Very hard to tune because of the phasing issues. But the results are worth while. One the sub, you need a cone that will maintain stiffness under flex, and light enough to respond to transients. When looking for a sub, look at the lowest rated frequency it will play. The a/d/s 310RS would play clean down to 18hertz. Believe it. Most 10's go down to the 30's if you find one that will play below that, you are good to go.
The frequency response of the Morel Ultimo 102's that I am using theirs play from 10-900. The Voice Coils are 5.1" in diameter and will handle 1000 watts nominal and 3000 peak. They are not efficient at only 87db, so you really need to throw a lot of power at them.
Calgary
I'm not planning on replacing any of the speakers, I don't really see a point if I'm not going balls deep with the dsp
antarctica24
antarctica24
O'Fallon, MO, USA
Thread Starter #18
I have a sealed box as well
Best Kind.
For those interested why I would say that, A sealed box maintains better control over a subwoofer than a ported one. And a ported enclosure has to be tuned to the car. Otherwise you get a large peak in the vehicle at the resonance frequency of the port. This can create a boomy sound in the car, in addition to the already resonant frequency the cabin creates.
neeqness
LA
Hi @antartica24,
Just wanted to come in and thank you for posting this. Almost a year ago I read this and put in a stage 2 for about $150 (no stage 1 - as I use Android and Rhapsody/Napster and some of that player stuff kind of went over my head).
However I'm very happy with the results. I know it can sound better but this is much better than I expected especially considering what I put into it time and money wise. Your post was key to making it happen.
Thanks again bro.
