Springs, braces or swaybars? Which is best?
alexrex20
Spring
#61
Chassis rigidity is a buzz phrase the manufacturers love to use when showing off their latest and greatest sports car. Chassis rigidity is the name of the game, especially if they can also do it while being lightweight. Are we to believe that the Fiesta hatchback which is fundamentally a $15,000 Econo hatchback, is more rigid than a Corvette, or Ferrari, or BMW M3, or Lamborghini?
Seattle
#62
I'm still waiting for his data that proves that bracing does not work. He can say anything he wants on the internet, there will always be a yuppie brown noser to believe him. If he can't provide data to prove his statement, then it is no different than mine. At that point the only difference is that I actually have experience with braces and he does not.
At this point I will accept data from any platform that shows that bracing does not make a difference. I'll wait.
Right, the difference is you are modifying an existing platform that Ford engineered and was designed for performance. As far as I'm concerned you are the only one that needs provide the data.
Middlesex county
#63
OP, if you don’t mind the ride height, I would start with a RMM first. If you don’t like the ride height and you don’t want a choppy ride get progressive springs it’s not gonna hurt anything. Both are simple installs. As it’s been stated, driver education is important, but unless you plan on regular track visits, do what makes it a joy to drive on the street for you. You don’t need to be a professional driver to enjoy the car as long as your not trying to push it to its limits on the street which nobody should be doing anyway.
alexrex20
Spring
#64
Yes, the Fiesta hatchback unibody was engineered and designed for performance. lmao
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
#65
I guess I will chime in.
I have spent many years doing road race track days with the Cobra Club at Willow Springs Raceway.
On many of those days we had special guests come to the events and we were able to talk with them and learn from their experiences.
I remember spending many hours listening to a wise old guy, driver, builder, and team owner and his experiences about racing.
When referring to unit-body cars he always said that body flex was very unpredictable.
It was recommended by him to stiffen the body/chassis as best you can because you can always tune the suspension.
I do agree that one's driving ability is very important and a professional driving school is great however, why not also make the car work for you rather than against you.
A full race tube chassis is of course the best way but a little impactable for a daily driver.
Body bracing is the next best thing.
Yes, it is unnecessary for most but if you want to push your car to the edge it works great.
That being said, I would do tires, springs/struts, and sway bars, first and in that order.
Also be aware of where your springs are made, good steel is very important, so over time their rates don't change.
BTW, that wise old guy was Carol Shelby.
Dave
Seattle
#66
Knew you'd say that. Isn't that why they have existing torsion bars on the vehicle and different suspension than the standard fiesta? Think what you will, but I agree with BRGT350's comment; without being a full on track car the benefit isn't there. I'd stick with just getting yourself a RMM.
danbfree
Tigard, Oregon, USA
#67
I will say out of all this, at minimum a 2 pt brace/traction bar is going to help put the power down and help with turn in, that much has been proven. It just depends how much you personally feel it, but just about everyone who has done it says that it certainly does help and for ~$100-130 seems like a good investment. After that, personally I'd do an H main sub frame brace, but that will be much further down the mod list than the 2 pt./traction bar.
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
#68
Same story, different players.
We do not tolerate flaming on this forum.
Please keep your comments on topic.
Dave
felopr
JD
#69
What H main subframe brace you referring?
http://www.piercemotorsport.com/2014-2018-fiesta-midship-brace/
This?
Middlesex county
#70
No it’s the one that attaches to the lower control arms that he’s referring to. I have the TB Performance one but pierce also makes one that attaches slightly different but same effect if I’m not mistaken.
Edit: my bad I only saw him refer to the 2pt brace. Yes thats the midship brace he was talking about.
alexrex20
Spring
#71
Do you know what a torsion bar is?
Seattle
#74
It stiffens the chassis... And has its trades offs. Obviously independent is best all around. This is a 20k car Alex.
danbfree
Tigard, Oregon, USA
#75
danbfree
Tigard, Oregon, USA
#76
Yeah, the '16+ got thicker torsion BEAMS so they don't need a torsion BAR as badly... I'm actually impressed by the lack of rear hop/steer compared to my last twist beam rear car...
Middlesex county
#77
If I were to pick one it would be the traction bar. With the front wheels working together the car is much straighter with a lot less effort off the line and comes out of corners with a lot more traction. I noticed this not only because of the feel, but with traction control still enabled it doesn’t come on nearly as much. Of course a real LSD would make it much better, but for a fraction of the price this does very well.
danbfree
Tigard, Oregon, USA
#78
This is the exact kind of feedback I was looking for, thanks!
alexrex20
Spring
#79
That is not at all what the torsion beam does in a torsion beam rear suspension. Yes the Fiesta ST is about 20k but it is based on a car that is about 13k. Ford did not add any bracing, despite your completely ignorant conception of what a torsion beam is.
BRGT350
Grand Haven
#80
I have gone over this subject many times, but the weight of the vehicle is supported at the spring perches at all 4 corners. On the rear, the springs are mounted on perches at the frame rail under the hatch floor. The rear of the vehicle exerts force on the spring and the spring pushes forces back into the perch. It equally applies force on the rear suspension, which has the opposite perch. The springs sit vertically and the forces are vertical. Under cornering, a small horizontal force is induced into the spring as the rear beam rotates around the rear roll center. Given the short height of the springs, this horizontal moment is pretty small. Any horizontal force is transmitted into the spring perch and the frame rail. That force is distributed into the unibody. The minimal horizontal force puts the hatch floor into compression. The geometry of the rear floor includes a number of surfaces that affect the MOI, increasing the stiffness. Ok, so that covers the rear springs. There are no braces for the rear spring perches.
Oh wait, there are braces for the rear shocks. Ok, lets break down the rear shock area. The shocks are mounted to the twist beam and to the chassis inside a box section that is welded to the hatch floor and the inner quarter panel. The shocks are mounted vertically. The compression force in the shock exerts an equal and opposite force on the shock mount. The force direction is vertical. There is a bushing of some compliant material at both ends of the shock. This allows for some articulation as the suspension rolls. The bushing acts like a compression spring. When the vehicle is in a roll state, the vertical forces receive a horizontal component. The bushing allows the shock to deflect and provides a spring force on the shock. The horizontal force exerted on the chassis at the shock mount is transmitted into the box section of the mount and into the unibody. In order to deflect the box section of the rear shock mount, the inner quarter panel must also deflect, which is welded to the entire unibody, meaning the horizontal shock force needs to be great enough to a large portion of the unibody in order to require bracing to prevent deflection. But wait, none of the vehicle load is passed through the shock! It is passed through the spring. The spring carries the load and shock dampens the spring forces. But there is a horizontal spring force during roll! Yes, but given the low vertical force of the shock compared to the spring, the horizontal component is pretty much nothing. Any deflection caused by the horizontal component is taken up by the compliant bushings. In order for the rear trunk brace to counteract any horizontal forces caused by the shock, the shock's horizontal component must be great enough to fully compress the bushing creating a direct load transfer to the shock mount (the one on the shock assembly) and then transferred to the chassis shock mount along with applying a shear load on the fasteners. Now, if you have ever taken the rear shocks off a Fiesta, you will see how incredibly small the upper shock screws are. Meaning they aren't designed for a great deal of load. Since shear is a weak strength condition for a bolt, if the engineers saw a high shear load, they would need to increase the fastener size. Bolts and screws do much better in compression and tension loading. The small fasteners is a clear indication the loads at the chassis mount are vertical, placing the fasteners into a compression and tension load condition, where they are much happier. Take a look at the shock mount at the twist beam, it is way bigger! Why, well, the shock puts the bolt into shear, so a bigger fastener is needed.
For the rear trunk brace to do anything in a roll condition, there needs to be enough horizontal load exerted into the chassis to deflect a large section of the unibody. Given the HSLA steel that was used in the construction of the Fiesta (if you know your Fiesta history, you will know that Ford had to design new blades for the jaws of life in order to cut through the unibody since it had a far higher grade of steel than what was being used at the time for car construction), the small size of the upper shock fasteners, the minimal horizontal force exerted on the chassis from the shocks, and the fact that the vehicle load is transmitted through the spring perch under the frame rail, it is highly unlikely a trunk brace offers any significant strength in the chassis due to cornering forces. Wait, how are cornering forces generated? Tires. A typical summer tire won't produce enough traction to create enough cornering force to deflect the unibody construction. The cornering force must be transmitted through the tire, which has some absorption into the tire carcass, then into the wheel, which deflects and absorbs some of the force, into the wheel bearings, into the twist beam, then through the soft rubber bushings, and then finally into the chassis. But racecars uses braces. Yes, they also use tires that produce far more cornering force and use solid bushings that transmit forces much greater than soft rubber. They are also designed for a greater level of chassis rigidity to take advantage of the stiffer suspension, bushings, cornering forces, increased safety due to the far higher speeds and forces exerted in a crash, and are driven by drivers who can actually feel the difference in suspension and chassis tuning.
But deflection is bad! Yes, chassis deflection is bad. Since none of the rear suspension pick-up points are located in the trunk, the forces aren't transmitted through the trunk area in order to cause enough deflection to alter the suspension geometry. There is far more bushing deflection that alters the suspension geometry. The stiffness of the rubber bushing is far less than a steel section with lots of geometry to create a higher MOI.
So, tell me how a trunk brace is going to decrease the deflection on the unibody when it requires a high amount of horizontal forces exerted on it to place it in compression or tension (because that is where a single beam is the strongest), the forces are transmitted into the frame rail under the hatch floor, and there are 6 rubber bushings with a high degree of compliance deflecting under load?
As for my paper on the wall, I am sure you don't listen to doctors since they have a paper on their wall. You don't think pilots should fly you around the sky with their paper on the wall. Let a lawyer defend you in court with their paper on the wall. You don't know the amount of work I had to put into that fucking piece of paper, so don't tell me it means nothing.
