Nope, i went from OE to Eibach springs to Bilstein B8's and Eibach springs. Now im Bilstein B8's with Swift springs since the Eibach was WAY too soft in inital rate. It caused the car to roll significantly more than even the OE springs.
Right now im good with the B8/Swift combo. Car works wonders on track with the 15x7s and 205/50's and if i have to bitch about something its that the initial turn in response is "muffled" with the 15s versus the OE size 17s. My strut/spring combo is not limiting me right now so the plan is to stick with what i have for at least another year.
Fortune Auto 500's have a larger shock body than the Bilstein. Single tube versus twin tube. Are rebuildable locally to me while Bilstein needs to be sent away. They are height adjustable versus just springs. The front rates can easily be changed. The rears are still a divorced setup and use a lowering spring but the rate is already at or over 350lbs/in. So its over 100lbs/in more than my Swift setup right now. The fronts are even higher. But again, im not having trouble right now. The car is compliant but still a capable track/autocross car.
My next move is going from 15's to 16's. I bought some 16x7.5 Konigs on black friday(under $350 shipped) and will pair them up with 215/45 BFG Rivals. Ill still keep my 15's around though but im hoping to get back some turn in feel going up to a 16" wheel. That is my biggest gripe right now - loss of turn in steering.
