I'm tired of farting around with my 3D printer, trying to print a pair of wedges that takes out the negative rake in out front bumpers so that I can mount my flat belly splitter parallel to the ground. I believe that the Triple R composite splitter does run parallel to the ground but I can't find any in stock. The Maxton that I had did not. Can any of you confirm that the splitter that you have is molded with wedges and does run parallel and flat to the ground? Thx!
