I no longer need this. I’m selling it as an entire bolt-in assembly. When I removed the side part, the little hook cracked. I used hard epoxy to make sure it wouldn’t break completely. It works as it should and I had no problems with it after the repair. You can always remove the Boomba Shortshifter and install it your assembly if you’re worried about it. This also comes with red bushings (Shifter and transmission) which you can see in the pics. Price is $200 plus shipping and fees. I’m in Atlanta if you want to pick it up locally.
