Softest Adjustable Dampening Coilovers
Earth
I searched and couldn't find anything specific on this topic. I want to upgrade my suspension so I can soften the hell out of the of the ride, for daily use and long road trips, then firm it back up quickly for backroad runs.
Are there any coilovers where the full-soft setting is fairly cushy compared to stock?
Thanks.
danbfree
Tigard, Oregon, USA
I would say the ISC coilovers. They make comfort, street and race versions and each can lower from 0-3" and has 32 levels of dampening adjustment. What I couldn't tell you is if street on softest setting would be enough for you, but "ISC N1 Fiesta coilovers" might be a good research term, and they are just under $1000 a set with lifetime warranty.
ron@whoosh
Vendor
Las Vegas
Thanks.
the best option for "comfy" coilovers is a set you can have custom built for no added expense.
Silvers are by far the best option for what you are asking. The top bearing plate can be upgraded, you can select your front and rear spring rates, and Silvers are built in the same factory as Fortune Auto. let me know if you'd like more information
https://whoosh-motorsports.myshopif...-2014-fiesta-st-custom-spring-rates-available
K
Earth
Thanks, Ron! I'll shoot you a message about it.
