Well I was hoping I would have been able to avoid breaking things with only 8000 miles on the car but then you put my dumb self behind the wheel and anything can happen.
Tonight I met a friend for dinner and took a little romp before hand. Decided it would be a good idea to do a little burnout. Mind you this is like the 3rd i've ever done in the car. Well first gear goes fast as most of you probably know, threw her in second and after a second spinning seemed to stop and two seconds later seemed like clutch was slipping. It was a weird experience. Anyways pulled up to a stop sign and had some bad smells which I initially attributed to roasting tires. After a minute though and another stop sign was thinking much worse. Car was driving fine though so I parked and went in and had dinner. Left about 90 minutes later and now first and second seem to stutter from a stop. Just a slight dut, dut, dut real fast. Best I can tell 3 times. Not noticeable in other gears, not noticeable downshifting to second for a turn.
Any suggestions?
Any suggestions?
