I got $$$$ on it the Slave Cyl line is missing its Rubber seal that is on the end. Its most likely LOST into the Shop floor abyss or stuck inside the old Slave in the Trash.
You saved me, thank you. I went into the old slave cyl, and pulled that rubber seal out, and now I'm one step closer to be done with this diff install.
