I had a bad EVAP issue, as in 18mpg on the freeway, gas smell all the time, tons of gas in my oil, etc. I was also getting a strong oil burning smell inside my car. The indications were, excessive fuel flowing into the oil was causing my oil level to be way too high, resulting in a lot of oil being burned. Now that the evap issue is fixed, I get ~24 city (up from 18 highway), and no more "dying at idle" after fueling up. It's a net positive, no more burning oil smell, but still "overly strong" exhaust smell, and exhaust smell in the car. I then tightened up my rear hatch significantly after marking the gasket with silicone grease, closing it, and finding out it wasn't making 100% contact. It's now making 100% contact, so the in cabin exhaust smell is reduced, but it's still a pretty strong exhaust smell, much more than I remember when it was new.
The reasons I think I might have cat issues:
The reasons why I am not sure:
Anyone familiar with some FiST specific behaviors for a failing cat? When I get a chance I'll hook up my FLIR camera and pull some temp readings off the cat, not sure what else to check. It fails the smell test, but passes OBD2 checks and the "runs totally fine" tests.
I'd go to the dealer, but I'm kinda burned out on them telling me theres nothing wrong (then I wind up going home and fixing it myself, like my trans being "fine", but they only put 1.5l fluid in it).
- I'm stock/untuned, back to stock exhaust, stock downpipe. My exhaust smells really strong (like, even after 3-4 hours on the road, it smells like it does during cold-start.)
- The last couple mornings, when coasting to a stop I noticed a faint rotten-eggs smell, which historically = bad cat. Unable to absolutely verify it was my car, though.
- As the weeks go on, my exhaust is getting more and more "poppy". Stock exhaust, but its sometimes popping alarmingly loud, and while inching along in traffic, not downshifting or compression braking.
- That cat must have been taking a beating, since I was getting 18mpg highway. All that unburned fuel had to be going somewhere, and I can't imagine it did nice things to the cat.
- I can't hook up my access port to check codes, so I bought an OBD2 reader. No codes stored.
- At idle, the exhaust smells fine.
- The car is running great, not at all like it's got a clogged cat.
- No chunks of catalyst fell out (usually a strong sign something is amiss).
