If you have cheap stance type shocks, but quality shocks from a Bilstein, Penske, MCS, JRZ, SACHS, Etc will over lay within 2-5%. I can take two Bilsteins off the shelf for say a Miata and the two front shocks will pretty much over lay. Cheap shocks not so much. The Chinese/Taiwan shocks are all over the place.
Bilstein has the best quality control of any of the OE sized shock manufactures. Their shims and pistons are extremely well controlled. I can pretty much grab the same shims from the box and assemble the shocks and they will be the same. If you dyno them, they will almost 99% of the time over lay. For a street car, they will always be close enough. For a track car, I might spend the time to dyno it and chase the extra few percentage.
A quality supplier will never let shocks out of the door with enough variance that would require running a "6" on one corner and a "7" on another corner in order the balance the forces.
