Here is my take after 10 years of instructing.
First, OEFvet11 offers some greate advice.
My advice for a newb:
Have fun! and listen to your instructor!
Bleed brakes before your event (I love me some motul rbf600)
Stock pads/rotors are ok (for future, get track pads/rotors for the front and switch at the track)
Nut and bolt check before event..
Check tire pressure after your session when the tires are hot (No idea for baseline tire pressures when hot)
Slow in, fast out.. Be smooth with all inputs. Learn to pick reference points off track (a house in the distance to aim for, for example)
Bring tools, water, a present for your instructor, ask questions, be open to feedback, clean our your car (nothing lose), jack/jack stands, etc.
Never use your E-Brack while at the track!!!!
Have Fun!
Your Questions:
Cooling - Straight distilled water or should I leave the coolant as is?
->Leave Stock
Would it benefit the cooling to remove the hood heat deflector(the cloth like piece stuck the underside of the hood)?
Also, would removing the engine cover help with cooling?
->No real benefit.. But motor noises increases and that is a good thing.. The Fist is quiet imo
How about removing the cowl?
->dont be dumb.. No point..
Would I help the car by popping the hood immediately after getting off the track and then actually lifting it up after I can finally stop?
->Never pop your hood while driving! But opening your hood when parked after your session is a good idea.
Brakes - removing dust shields and adding the boomba deflectors? Has anyone actually tested these deflectors with positive results?
->Removing the dust shields is ok, but not needed. No idea about those deflectors.. save the money
Oil - I run Pennzoil Platinum full synth 5w-30 in this engine, all the time. I assume I am ok with this oil but would like to hear opinions on it.
->Bring extra to the track and check after each session.. Force of habit for me since I use to track a Honduh..
I will have about 5k miles on my oil when it is time to go on the track. Would it be better to put fresh in for the track then change afterwards, or just leave the current oil in the car then change it? I normally change it at 7500 mile intervals.
->Change it before the event and soon after.
I'm also currently at 23k miles on my transmission fluid and will probably be around 26k at the event time. Would it be better to change this before or after?
->You can change before or after.. Depends on who lazy you are.
Fuel - I can get 98 octane at the track. Would I benefit from this at all or hurt the car being that I'm 95% sure I'll be using the Cobb Stage 3 OTS tune during the weekend. Should I just stick with 93 E-10?
->Track gas is mucho$$$$$$.. Stick with 93. Dont mess with tunes.
<-Trying to avoid doing work..
Have Fun!
Your Questions:
->Leave Stock
