I have a few questions concerning the FiST on track. I know there are a lot of variables when tracking the car, track layout, weather, driver, parts used on the car, etc...
I'm hoping to get some answers and/or discussion the best setup overall to keep the FiST's engine cool, brakes cool and also keep the performance as high as possible for as long as possible with a minimum amount of investment.
I will be on track during Hyper-fest, at VIR in May.
I did the same event last year in HPDE 1 and rode with an instructor the whole weekend. I will be HPDE 2 this time around and hope to go Solo on the 2nd day. The weekend consists of 8 sessions on track between 20-25 minutes long. Therefore, I might be pushing the car a little harder, although, I pushed it VERY hard last year and it did fine.
The car was completely stock other than Hawk DTC-60 pads on the front(kept stock pads on rear) and Torque RT-700 brake fluid. I did remove the front brake dust shields to help with cooling. There were about two times that
I had fade when on track. The car did fine all weekend, except the couple braking issues and had no overheating issues that I know of. I did not monitor temps at the time, so I don't know exactly how hot the oil and coolant was getting but I never lost power and the car didn't go into limp mode.
I'm currently Stage 3 Cobb OTS tune with mods in my signature.
Some questions I have:
Cooling - Straight distilled water or should I leave the coolant as is?
I'd like to get as much cooling as possible without adding an oil cooler or radiator and am not sure if straight distilled water would be the best bet. The temps will definitely be above freezing the whole weekend...
Would it benefit the cooling to remove the hood heat deflector(the cloth like piece stuck the underside of the hood)?
Also, would removing the engine cover help with cooling?
How about removing the cowl?
Would I help the car by popping the hood immediately after getting off the track and then actually lifting it up after I can finally stop?
Brakes - removing dust shields and adding the boomba deflectors? Has anyone actually tested these deflectors with positive results?
Oil - I run Pennzoil Platinum full synth 5w-30 in this engine, all the time. I assume I am ok with this oil but would like to hear opinions on it.
I will have about 5k miles on my oil when it is time to go on the track. Would it be better to put fresh in for the track then change afterwards, or just leave the current oil in the car then change it? I normally change it at 7500 mile intervals.
I'm also currently at 23k miles on my transmission fluid and will probably be around 26k at the event time. Would it be better to change this before or after?
Fuel - I can get 98 octane at the track. Would I benefit from this at all or hurt the car being that I'm 95% sure I'll be using the Cobb Stage 3 OTS tune during the weekend. Should I just stick with 93 E-10?
I appreciate you all and this forum, it's a great resource and hope it is for years to come.
