I used 50mm plastiflex pipe. 50mm is a little on the small side but it was a major hassle because there is very little room to work with. This supplements the OEM system which picks up air just in front of the radiator. The problem I see is that the factory inlet faces the radiator instead of facing forward. The air flow has to travel through a 180 degree turn and two 90 degree turns before in can enter the air filter housing .
See the images and you can see what I have done.
I am not 100% happy with the front air inlet at the moment, It needs a tidy up and I may add a small section of some type of mesh material. I am open to suggestions on how to make it look better from the front view.
