Okay, time for an update. No new parts since last time, but after the last event I was unhappy with how the car is rotating. I pulled the rear shocks so that I could increase the rebound. The shocks had been set at 50% stiff, one turn of two. I wanted to move to 1.5 turns. I had forgotten how much of a chore it is to set the Koni Yellows. The shocks have to be removed from the car (easy) then remove the top mount (easy) then fully compressed and turned(pain in the ass). The shocks take a good bit of effort to compress and it's hard to tell if you have them pushed into the detents that actually change the shock setting. Get ready for some uncertainty and sore palms before you get this job done.
Our next autocross took place at the Michelin Proving Grounds, nicknamed the Black Lake because it is a huge completely piece of asphalt used by Michelin for wet tire testing. This site is actually smaller and less grippy than our main site, but gives us a look at different types of courses than we usually run.
With the shocks being the only change made before the event, setup on site was minimal. I used 33psi for the Rivals up front and 42psi in the rear. No complaints about how the tires drove, but looking at shoulder wear, I think I'll be moving up a few psi in front to cut down on rollover.
The shock adjustment did exactly what I was hoping for and some of the rotation is back. It still isn't as loose as stock but the improvement is evident. I would like a bit more rotation still, but I'll wait until another event at our normal site to make a final judgment as to how much further to go.
Finally, the results from this event were my best so far this season. My first two runs had me in the mix but in 3rd place with most times close together. I decided to be more conservative at a couple places on course hoping to carry a bit of extra speed and it paid off better than expected. It feels really good to knock off 1.5 seconds from a previous run, but that also shows how poorly I attacked the course before. I wound up taking first by about 0.6 seconds which is my healthiest margin this season. I paxed 31st of 119, which I think is better %-wise than my other events this season.
https://youtu.be/rB8MVeN2ChM
This is my 3rd and fastest run. I was the last STX driver and knew I'd won the class before my last run so I was able to take it easy for my 4th. I didn't like the sweeper at the far end of the course. According to Solostorm, I was driving at +1g for 7 seconds. That made me worry about oil starvation, but I didn't have any problems and we had 120 drivers with no mechanical failures so I was apparently worried about nothing. Otherwise it was a great course and a lot of fun. That's why we do this right?
