Ok kids, I know there have been a couple threads regarding tow hooks and straps, but relatively few examples. If you've done them, please share pictures of attachment (if you have them).
With Ford's inexplicable omission of tow hook mounting points on U.S. cars (Focus ST and Fiesta ST), at this point I'm a bit resigned to having a custom welded on bracket made and coming through the faux grill (or wherever the best spot is back there). Might be a place in the back to mount a hook under the car. Worked with the SVT Focus.
I do like these: M-17954-A
I found this mounting approach for a focus: https://www.dropbox.com/sh/i2xnf20dxpl0oht/AAAV-k95cYqTrb6QYeIiVE__a?dl=0
I figure to do something similar.
There are options intended for Mustangs that might be able to be modified (meaning with brackets that can be cut and bent as needed, then welded to the the bumper beam), like this: http://www.summitracing.com/parts/f...kegQzq5x4Jn41gQvHr35Ud_uBE1lc1PkDhxoCTFvw_wcB
Otherwise a custom bracket. Bleh.
I read somewhere in passing that Ford does not recommend the strap approach. I do not recall where or why.
