Reverse is dead
its_stock
Thread Starter #24
I can either rebuild the reverse synchro or I can call puma speed and order a new transmission. Spoiler alert I already called puma speed
Did you grind/crunch going into reverse more than once, or did this happen all on it's own? [dunno]
its_stock
Thread Starter #26
Honestly I never abused reverse and it didn't show any signs of failure it just broke. I could understand shearing all three of those keepers if I was going 10 miles an hour and I threw it in reverse or something but I didn't.
#31
My favorite pic...
Reverse is failing here too. It locks up once in a while, seems maybe the lockout mechanism engages. Hard to get any gear regardless of clutch pedal.
Time for a Clark unit*
XR650R
#33
So I rebuilt this motor mount about two oil changes ago less than 10,000 mi and it's already failing again. S280 (2) Mountune (0)
I think you need the stiffer inserts. Ask Ron if the Whoosh inserts would fit this. They look to be the same size, but IDK.
#34
Do you have upgraded passenger side and/or transmission mounts as well?
its_stock
Thread Starter #35
I have the energy suspension inserts in both side mounts. And I just ordered the complete Vibra Tech set from Whoosh. Fingers crossed Ron sent them overnight.
XR650R
#38
Also, it doesn't look like you lubed it.
