Just rolled over 10,000 miles/16,000 kilometers and an amber wrench popped up?
These are the exact steps I used to clear mine:
1: Uninstall AccessPort
2. Turn ignition on (push ignition button, but do not press the clutch in)
3. Depress brake and gas pedals 100% (light should go off after a couple seconds)
4. Count to 30, then turn your ignition off
5. Start the car just to double check the light doesn't come back
6. Power down
7. Reinstall AP
If you have an accessport installed, it needs to be uninstalled to reset the oil change reminder. If following the above directions still don't work you can try holding down your brake and gas BEFORE hitting your ignition button. That was a tip from my Ford dealer when I was having similar issues, no idea if it works. If all of that is a fail, then maybe it unfortunately ISN'T an oil reminder, but a powertrain warning light.
Keywords: resetting oil light, resetting wrench light, resetting oil, oil reset, clearing oil light, clearing wrench light, oil reminder light
6. Power down
7. Reinstall AP
