Replacing part of the EVAP line
Ottawa, Ontario, Canada
Hey all. I replaced the intake manifold on my 2014 and I had to remove the broken connector for the EVAP line. The opening is stretched and won’t fully seal and also there is a small cut that would be at the end of the nipple. Is there any way to fix/replace this small piece without changing the whole lines?
Jabbit
New England
I tried to do the same thing and failed, ended up buying a whole new harness. A bit overkill but it isn't multiple part numbers, the harness is all one piece. You could maybe try some sealant tape or jb weld it something but it's probably going to cause you trouble down the road. You could also try buying some vacuum line.
Jabbit
New England
I can dig through my box o goodies, I have most of my original harness. You might be able to cut up a portion of and it and use it. Let me know.
