Inner trans case cracked, leaking fluid. Replaced the part, but now she won't start. When we first started trying to get the car to crank, it would attempt for about 20 seconds, then shut off -OR- when I held down the accelerator while pushing the start button, she'd crank for 20 seconds, then immediately start and rev to about 3k, then die. Error codes P0223 (Throttle/Pedal position circuit LOW) and P0123 (Throttle/Pedal position circuit HIGH) are constant. We've double checked all grounds, throttle body has been replaced just to be sure, and yes the battery is charged.
Now the engine will not attempt to turn over - I don't know what changed, but it just won't. Seems to me as though the clutch sensor is not reading correctly, but we checked it out and it is reading correctly. I push to start, all the electronics come on, but when I push the clutch to start, she just turns off, as if the clutch was not pushed in.
If anyone has similar issue, or knows how to solve it, please help.
