Thought I would share my install pics since I haven't seen anyone else install a remote oil filter.
No need to use one for most builds but when I was planning out my single port aux fuel install I realized what little space I had between my oil filter and my CP-E charge pipe would change after I added the sandwich plate between the TB and the intake manifold. I figured I had 2 choices; either go back to the OEM cold side piping or install a remote oil filter. I wanted to keep my CP-E charge pipe so I ordered a universal remote oil filter kit from Jeg's. Cost was under $50.
It came with some pretty decent quality hardware.
I intended to use rivnuts to mount the filter base and luckily I had the space just above the cold side charge pipe. I made a template for drilling the holes.
And some more pics of the installation.
I went with a FRAM filter because of its higher filtration spec over the Ford 910S.
