Razor send me the "required param" to log list. I'll try to get yall one. I just took some really great logs intead of eating lunch. So i don't forget, they were taken at 83 degrees. Its a rare warm day here without the humidity so 83 feels amazing instead of really crappy. I had some knock retards this time, but I did bump up the boost map SLIGHTLY SLIGHTLY and added 1.50 degrees of global timing above 1.85% load. Between all that, i expected to see a bit of retard, just wanted to see where and at what pressure. The retard did not exceed 1.00 on one cylinder ( but I'm only watch 3 currently ). I have another slot built into the tune without the 1.50 degrees of added timing, so its just a switch away.
That whole in the timing from the pic above is a bit of mystery to me around that 5500rpm area. I did notice it. It maybe a hole/over-sight in the timing map? Or something else I'm missing, but its not coming from "ign. Timing correction" on that log.
The logs that I'll post tonight will be multi-gear pulls. Different gears, and some even have 5th gear in them. Should show a lot of short comings with the stock intercooler and maybe the radiator.
