QUITE the douchy reply.
I have boosted and turbo/ custom engine-swapped cars, put on and setup coilovers with tubular susp parts, tweaked my own tunes, understand timing fully.....so i assure you im not a non performance driver. This is my.......5th Ford ST vehicle. Non of them were stock. The fact that I have driven on the all seasons i just ordered in the snowy winter of 2011 lets me know they work well.
My potenzas will be going on a spare set of 17's i have. In the summer im gonna redo those wheels and use them until they are shot. Im not about to spend over $500 on steelies and dedicated snow tires for a dec-feb timeframe. I like all seasons.
I drive hard but i can adjust the limits i drive based in the tires. Its my daily. If i want nuts i will go drive my frankenstein car that is down right unsafe fast lol.
I never saw an option. Just rado grey. Does anyone know what tires they offer?
Yeah, how many of your cars are still on the road? Not many from what I understand. Anyway, no reason to argue that, let's stick to data instead.
1) The 2015 Fiesta ST has an option for All-Season Michelin tires, so a tire option does exist. I looked at a ST last week with the factory installed All-Season tires, and saw another one back in January. To suggest no tire option exists is false.
2) The owner's manual, along with the tire companies, all say that summer tires should not be driven below 45'F or 40'F (it varies based on the source) and the reason is the compound doesn't adhere to the road at temps below the suggested range. The rubber formulation is designed for higher temps and loads instead of cold temps. They all suggest to avoid driving in snow and this is due to the compound, tread block design, and the lack of self-clearing tread.
3) The average temps for Landenburg, PA is 36'F for December, 32'F for January, 34'F for February, and 42'F for March. That indicates that under a normal year, there are 4 months in which the average temp is below the recommended tire operating temp that is published in the ST owner's manual and against the tire manufacture's recommendation. Regardless of snow fall, the temp range indicates you should be using something other than a summer tire for that time period.
4) It isn't about driving the car hard on the street, it is about being safe and not putting yourself or others at risk. Operating a tire outside of the designed temp range is no different than operating outside the pressure range. It increases risk of a problem. Example, if at 32'F a summer tire takes 120 feet to stop from 60mph and an all-season takes 100 feet to stop and there is a kid that ran out in front of you that is 110 feet away, then you just took out the kid with summer tires. With snow or ice, the stopping distances increase greatly and a proper winter tire is your only option to safely stop or maneuver away from an obstacle. This isn't about FTD on the street, but about safety. Using a tire that isn't designed for the conditions is unsafe and puts others at risk as well. With summer tires on snow, it may take 250 feet to stop from 60 mph, 150 feet on all-seasons, and 100 feet on snow tires. The braking ability of a winter tire on snow is their most impressive asset. Way more so than acceleration. The best way to survive and accident is to avoid an accident. The proper tire adds an extra factor of safety in avoiding an accident.
5) Spending money on tires is the most important thing to spend money on since they are the only connection between the car and the road. Maximizing the interaction between the car and road is the key to the dynamics of the vehicle.
While you suggest the reply was "douchy", I think the technical reasons and data prove my points. I also happen to be a suspension engineer and have completed a number of SAE vehicle dynamic courses which focus heavily on tires. If you have actual data to counter any of my points, please bring the tech. Suggesting it is Ford's fault for operating a vehicle with improper tires for conditions when the ST manual suggests you do otherwise is just silly. Ford is 100% in the clear since they offer an all-season tire option and have published warnings in the ST manual to not operate the car with summer tires in conditions in which you are currently in.
