Hotbits told me that they ONLY do Scoobie apps exclusively now.
The only affordable setup I've found, (but a real PITA because you MUST change back to the base Fiesta front knuckles/uprights in order to make it work without contacting our bigger than the base car's front axles) is the R1 gravel spec kit from M-Sport, using Bilstein motorsport spec sized dampers, which are NOT adjustable for rebound, or compression (they are fixed valve rate).
These are procured either through M-Sport Poland directly, or through O.D.D. Racing in Colorado (they have to order them from Poland as well), here in the states.
It IS ridiculous that NO ONE makes a direct bolt-on, NOT slammed to the effing ground like a stancer, even adjustable to the factory ride height coil over setup for these cars.
