Thread Starter
#221
Recent progress.
GT2560R install nearly finished, decided to stay with its stock compressor wheel
Passenger and drivers engine mounts now urethane filled, passenger side upper lightened, drivers side smoothed and buffed, I can barely move the engine, might be a bit to stiff!
Built new 2 point brace/undertray mount
Replaced all hard plastic lines with HD rubber hoses, SS wire wrapped all ends to ensure stay on.
New 6061 aluminum front caliper mounts designed and installed to move calipers in to fit 6ul wheels
New front knuckles as the stock ones had been modified to fit the BBK/15x9 wheels, no longer needed so went to stock knuckles.
Relocated and new lines for OCC to fit alumium expansion tank
Work in progress:
Design and install backing plates for brake ducts
Bent NACA ducts formed in undertray to glow air out through the wheel wells(like the Vette World Challenge unit I had on my race Vette)
New ECU and air filter housing mounts
Design and build heat shield with air duct for alternator as 1/4 of the oil cooler outlet blows directly on the alt now.
Finish all new radiator, IC, etc, ducting
Tap Mishimoto upper hose connectors for AN fittings
Work in progress:
