Questions about front windshield wipers.
eastern
Seen others on here that have tweaked the passenger side windshield wiper down lower. Just looking for how to do this.
Thanks.
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
To remove the wiper: Pull the cap off. Remove the nut (15mm). Press down before the spring-loaded portion while simultaneously pulling up to life the wiper off. Adjust wiper, press down, replace nut, replace cap.
Easy peasy, lemon squeezy.
Sekred
Mid North Coast
The wiper arm sits on a tapered spline. Remove the retaining nut and pop the wiper arm off the spline. Adjust the wiper arm to the desired position and refit nut.
Note, the wiper arm is a tight fit on the spline. There are small Pullers available to pop the wiper arm off the spline. You can damage the splines by twisting the wiper arm.
