Purge Valve with Filter?
XanRules
Portland
I replaced the purge valve about two years ago and haven't had any issues since. I fueled up today and didn't have any issues either. If your purge valve is already shot, you'll need to also replace it. Too soon to tell if addition of the filter is the solution but at least it's not causing any issues.
Got it - and you replaced JUST the purge valve, rather than the entire evap hose setup, is this correct? Thanks!
Nashville
I've cut open one ford purge valve, and found that the rubbery seal which is moulded to the piston was literally crumbling. I could squeeze it with my fingers and it would crumble into bits. If I still have my other bad purge valve kicking around, I might try to cut it open too. I know, sample size of 1, for a problem that thousands have.
Doesn't make sense to me, it should be some material which doesn't dissolve in gas, if it's used in evap. Maybe it's something else like heat that causes it to go brittle too quickly. These are only warrantied for 36k mi by the fed emissions warranty thingy, so not like it has to last very long.
Bull Run
U.S. Army Veteran
Chandler, AZ, USA
Should do a DIY with all parts used Etc* [driving]
I posted some pictures in my build thread but not sure there's enough content to do a DIY. It's basically:
3/8"silicon hose
metal tubing by the firewall -> purge valve -> check valve -> intake manifold
firewall to purge valve (this is where I spliced in the fuel filter later)
purge valve to check valve to intake manifold
I got rid of the other tubing associated with the venturi effect while under boost. My reasoning is that fuel utilization should go up while under boost and thus the fuel tank should not be under pressure at that time. Haven't had any issues since I did the mod a couple of months ago but it will be easy enough to add the other tubing back if needed.
Capped the cold-side pipe and induction hose.
Portland
#27
3/8"silicon hose
Thank you! Seems simple enough without spending several hundred dollars.
3/8"silicon hose
I like this Idea A Lot* I think i may convert in the warmer months. Thanks for he Info and parts list!
