ok, for the install, pretty straight forward:
Headlights, intake, battery and tray, cowl/wipers, disconnect exhaust from dp, dp from turbo- 1 of mine siezed causing a huge headache, oil and coolant lines, boost module reference lines, 3 turbo bolts on the manifold- soak in PB blaster before, remove from the bottom.
transfer DV, boost module thing mount,
![Wrenchin [wrenchin] [wrenchin]](/images/smilies/icon_smile_wrenchin.gif)
SWAP THE COOLANT PLUGS FROM FACTORY TO X47- THE PUMASPEED ONES LEAKED ON MINE AND WERE TIGHT AS A MUG
![Dunno [dunno] [dunno]](/images/smilies/icon_smile_dunno.gif)
- install wastegate- 0-1mm of preload, intake tune.
then fanagle her up from the bottom, have a buddy put the nut on from the top, then its the two from the bottom, coolant/oil lines, boost module reference lines, dp to turbo- antiseize please, dp to exhaust, cowl/wipers, intake, battery/tray, headlights, load your tune, check for leaks, add coolant and check oil, short drive, check for leaks, log your basemap, send to tuner, look in aww at basemap numbers....
