Ported Manifold vs Stock
Rochester, MN, USA
I am thinking about getting a the ported manifold from woosh along with the whoosh hybrid. Anyone else run this combo and notice a difference with the ported vs stock manifold? I see ron has a 5-10hp increase over stock but im just curious if anyone has ran one without and then got one and noticed anything.
akiraproject24
U.S. Marine Veteran
Pennsylvania
I have the whoosh ported manifold and hybrid turbo. The install will be taking place in April. They are going in at the same time though so I won't be able to note how it changes things on its own.
Pretoria, South Africa
Im gonna get my manifold ported here at a local engineering company. Got quoted 2500 ZAR which is 170 USD. Puma speed says there's hp and torque gains but lets see. Im stock turbo aiming to get 200kw which is 270hp. Almost there. Im 250hp rn
Also from RSA - please let me know if you get your desired Killerwatts. Who is doing the tune for you?
Fusion Works
Huntsville, AL, USA
I ported mine and ceramic coated it, but can't tell you if there was any difference in performance as I did the manifold, turbo and my 3.5in down pipe all in one go.
Fusion Works
Huntsville, AL, USA
I haven't driven any other S280 cars long enough to notice. My thought was the OE turbine outlet was 3.5in so I made my down pipe 3.5in figuring that would help with spool. My turbo starts spooling well below 1800rpm for what its worth. Don't really notice a bunch of lag even compared to stock.
Green Bay, WI, USA
Appreciate it.
Appreciate it.
