I'll be brief. Just recorded best mpg ever with me driving, 39.1 mpg. Then, 26.9 out of nowhere. No changes in highway/city mix, driving style, etc.
Things that happened in order of note:
-oil change on 10/5
-cleared old dtcs from several months back
-record 38.2 and 39.1 mpgs, sequentially
-filled up with gas and it stumbled as if i had tried to over fill the tank but i stopped at the first click as always
-yesterday noticed i was at 115 miles on a 1/2 tank. Usually closer to 200.
-cleared oil light
-recorded 26.9mpg
Other notes:
-AFR hovers around 14.7 under constant throttle, around 40 when cruising/shifting (no throttle), drops to 12.4 under heavy throttle
-seemingly no loss of power, boost seems normal for a tune, ~23psi
-oil may be slightly overfilled (can't see the word "max")... But two of my best mpgs ever with it overfilled?
-disassembled and reassembled intake to verify no vacuum leaks
-no smell coming from the brakes take 5
-accidentally pressed one of the cruise control buttons and RPM gauge dropped to 1k for a second...but engine RPM did not change.
What am I missing? Ask me questions. Just a bad tank of gas? Something else?
-oil change on 10/5
-cleared oil light
-recorded 26.9mpg
Other notes:
