Contamination would burn off with use of brakes. The tech seems to be scrambling to give an explanation where none is due. Video above is a perfect example of bearing failure. A "growl" would be expected further down the road, as it scores the interior of the hub.
Now this sound is clearly caused by friction, contact, rubbing, what have you. This all causes heat.
Have the car cooled down over night at the shop. In the morning have a tech take a short, normal drive. Very relaxed, very easy on the brakes, no more than 10 min. Just enough to get things warmed up and maybe get that noise. Have an infrared laser or a sensitive but cautious hand feel around the brakes, hubs, suspension. The brakes should be anywhere from warm to hot, while your suspension should be cool. Most importantly hub bearings that do their job do not induce friction, and therefore heat. The hub should be cool to very slightly warm. If the hub is hot, that is another sign that the hub components may be going bad. If there is any doubt drive another Fiesta ST on the lot or if you know somebody with a FiST with around the same mileage and driving condition that would be best. Compare them after a drive. Hopefully it'll at least help narrow down your options.
Any competent shop should have already done something like this.
But I would also stress in trying to drive the car as much as possible to get some wear in those brakes. Sometimes the solution is the simplest option.
Also relating to what the tech said, it's not always that bearings will cause a pull to either side. The only way you can really tell is to have everything properly aligned and with new tires, so it's the best way to rule out a possibility.
