So after installing a Sub and amp the other day after letting my car sit for about two weeks I had some weird issues/problems when I started her back up.
Initially had to jump her and on first start up, I went to go into first let out the clutch and gave her gas but got no response from my gas pedal. Checked to make sure my power line from my sub wasn’t blocking anything, As I went through the fire wall but saw nothing in the way. Turned my car off, went to turn it back on and the battery died. Weirdly wouldn’t jump at first but after fidgeting with the jumper cables a couple times it finally did. Once I got it jumped again, my gas pedal responded and I was able to start moving. Shortly after driving a short distance out of my neighborhood in first at low rpms, I got out on the main road and as soon as I got around 2500 rpm’s in first the power started breaking up and dropped down to a low idle then the motor shut off as well as white smoke out the back. Struggled to start back up, like it wouldn’t turn over just kept cranking then when it did it idled super low.
The below pictures are the codes it threw:
After reading a bit over night, I saw it could be as simple as reflashing the ECU. Tried that today, car started up fine but like the day before as soon as I got to 2,500 rpm’s it started breaking up. Didn’t stall out or die but happened every time I got to the same general RPM area.
I also read it could be the gas pedal position sensor. Battery holds a charge and charges fine, reading 14.5v while on.
Any insight is greatly appreciated, hoping it’s a simple fix before I drop 200$ on a new sensor.
