As requested, here is some detailed information on the valve cover breather modification that I added to my FiST. First, I went to a local Pep Boys and found a nice blue anodized aluminum plug to screw into my new FSWERKs intake inlet tube. This replaces the 5/8ths or 1/2" black plastic elbow that comes pre-installed into the intake tubing. I used some thread tape on the threads to insure a good seal. I also bought a white Spectre breather filter http://www.spectreperformance.com/search/product.aspx?prod=3998 at the same time (which you can also find at Autozone, O'Reily's, Pep Boys, or most other auto parts stores). I chose white so that it would be easy to visually check for oil leakage. I then headed to Home Depot to source a 5/8ths elbow with threads and 3/8ths brass barb which threaded onto the plastic elbow perfectly. Once home, I removed the clamp that holds the rigid hose that goes to the inlet tube, screwed the brass 3/8ths garden hose adaptor onto the plastic elbow and inserted the barbed side 5/8ths nipple into the remaining rubber hose. I ended up having to cut away a very small amount of the hose so that when fitted, the breather cap would not touch or vibrate against the intake tube. I then used a zip tie to secure. I plan on using a clamp so that I can position the breather and then tighten down but a zip tie works for now. The end results is below. This modification keeps hot, oily air (or gasses) from flowing into your intake which can in theory elevate intake temps significantly. Even with an open element air filter, IATs never seem to go above 10 degrees above outside air temps, even at long sustained idle and or heavy use. Is this what you were after MKVIIST? heh
