Boomba Ultimate Shift Package (Not so Ultimate)
I got my Boomba Ultimate Shift Package installed. The ultimate package consists of:
- Short Throw Transmission Adapter
- Transmission Cable Bracket Bushings
- Short Throw Shift Lever
- Shifter Base Bushings
Sorry, no pictures. There are lots of pictures out there on these installs, and I have nothing new to offer. For install instructions, Boomba provides PDFs, but I STRONGLY recommend watching the videos and not just follow the written instructions.
I installed this while I was also installing my CAI, so there was plenty of room to get in an get it mounted. I got a chance to drive with just this before I installed the short shift arm. Definitely provides a noticeable reduction in shifter throw and adds just a touch of notchiness, but nothing obnoxious. Overall Very please with the transmission adapter.
Also installed these when doing the CAI. Instructions call for puling out the battery box, which was pretty simple since I already had the airbox out. Installation was not too bad. Trickiest part is that the new solid bushings are a 2-piece design that does hold it self together like the rubber bushing/steel insert of the stock ones. I had good luck installing the rear bushing first, then was able to slip the other two forward bushings into place before tightening everything down. Can't say that I can notice any difference with these installed, but I did install at the same time as the transmission short throw adapter. I can say I don't feel any additional vibrations tough, so that's a good thing.
These go between the shifter and the base bracket. Easy install, the hardest part is getting the trim and center console removed. Again, can't say I noticed any real difference, but there is no additional vibration.
This is the not so ultimate part. I have installed and driven with it and won't be keeping this part. Install was a bit of a pain, especially removing the clip that holds the shift lever pin in. This is where seeing the video, and which way to try and remove it, is helpful. First, the positive... Once installed the shift lever is solid and when set on the max reduction setting, and combined with the trans adapter, really does shorten the shifter throws. For me on max setting, I don't really care for it and if I was keeping the lever I would probably adjust back to the 0% setting and enjoy the slightly better lever angle over stock.
So why am I not keeping it? I can't get the reverse lockout to function correctly. There is nothing in the instructions about needing to grind away additional plastic from the lockout mechanism, even though Boomba did acknowledge the problem over a year ago in a forum thread here (see link below) and noted the instructions needed to be updated. The missing step is annoying, but not enough that I would get rid of the lever. The problem is, I've ground as much plastic away as I dare and the lockout ring still does not function correctly. The problem is that it does not spring back down into position after it is pulled up. This sort of negates the lockout function and I think it's a bit of a safety issue. This forum post provides some more details,
Lockout Issue. As I said, if the lockout was working I'd just set the shift lever at 0% reduction and move on, I do like the better angle of the shifter. Since I have already hacked up my lockout mechanism, and gouged some plastic getting the clip out when removing the stock shift arm, I am just going to replace my current modified gear selector assembly with a stock non-modified one.
For full disclosure, I have e-mailed Boomba and explained my issues, and offered what I think is an amicable solution. I'll hold off on posting any specific details until I hear back from them and have given them a chance to respond.
Short version:
All the parts are well made and machined. Installation was pretty straight forward, but do watch the videos, as the PDFs alone leave out some subtle details. I liked all the parts. The short shift lever had a nice angle to it and can be set to the factory shift geometry, provide a 0% reduction in shift movement. If the reverse lockout was working correctly, I'd be very happy to keep the whole bit of kit.
