Cobb CAI / Boomba Short Throw Trans Adapter / Boomba Trans Busings / Broken Headlight
I finally have recovered from my cold enough to start installing the pile of parts I ordered. I decided to install the Cobb CAI and since that was going to be out also install the Boomba short throw transmission adapter and the solid transmission bracket bushings. Got through the install of the Boomba transmission stuff and still need to install the CAI.
Here's a nice stock before picture.
Cobb has you remove the entire cowl, I assume for additional access to the turbo to intake connection. Having seen many other CAI install videos do so without removing the cowling, I decide to see if I could get to the clamp on the turbo or not.
Turns out it was just too tight a fit for big mitts, so I decided to remove the cowl for some extra room. That's when the problems started. I had removed the two torx screws holding the driver side headlight in, but the 3rd Philips head screw connector was not coming out. Went a watched a quick video on removing the headlights and got some bad advice from the video. They recommended using a panel tool between the headlight and front radiator cover plastic to pry the pieces apart while turning the Philips screw. All I succeed in doing that was breaking off the mounting tab from the headlight itself. Same video also said to pull up on back of headlight, which I did when it would not come out. I should have wiggled more and pulled less, because I then broke off the rear mounting tab on the headlight assembly.
With my broken light in hand I called Blue Spring Ford Parts since I could not figure out the correct part number in their online parts tool. Got a bit lucky and the new headlight assembly was the $130 one not the $300+ one. Have a new one coming.
But the breakage did not stop. I then broke the locking tab on the harness side of the headlight connector. When the connector did not pop right off, I assumed the locking tab need to be lifted up. That's the wrong way and I broke it.
More parts to order, but I have a repair connector on the way and will swap the pins over to the new shell with the locking tab intact when it gets here.
After that I seemed to settle down got the rest of the parts and cowl removed.
As I was installing three different parts in one go, I bounced from instructions to instructions. Did get to try out my new Christmas present though and have to say it worked great.
Got the battery and battery box out with the rest of the stock airbox without incident. Hardest part of the entire install so far has been releasing the locking rings on the shift cable connectors at the trans bracket.
Right now the transmission bracket bushings are installed, the short throw adapter is installed, and I'm ready to put the CAI on and re-install all the other removed parts.
