Hey guys,
Driving home today I noticed that any time I would drive up a hill the parking brake light would turn on. Any ideas on why this is happening?
It's not just a light for the parking brake. It can come on for other reasons. Check you brake fluid level and add some if low. Low brake fluid is the most common reason.
Brake fluid level goes down as brake pads wear out. If his brakes are working ok but fluid is low he needs to have the dealer check pad wear. You should always check and top off the brake fluid when you do your oil change.
