Well for the 1st time at about 84k miles on my 2014 ST i have my 1st real issue. I got check engine light and 2 codes popped up P1450 and P2282. The car has recently started to stutter at idle and sometimes even stall at a light once the car is fully warmed up at operating temps. Other than the stuttering at idle the car drives and performs the same as normal. I run a Cobb stage 2 OTS map with cobb drop in filter, mountune intake tube, ATP intercooler with hot side pipe. Been running this setup since about 11k miles with no issues. Changed plugs with new motorcraft plugs at about 71k miles.
Anyone else run into this issue?
