So when I changed my oil at 1500 miles, I tried to follow the procedure to reset the oil life in the owner's manual and nothing happens. I've tried it a bunch of different ways. Door open, door closed, in gear, out of gear, no e-brake, with e-brake. Every combination. It still won't reset like the manual says it should. After some searching, I found this on another forum:
TSB 14-0202
FORD:
2014-2015 Fiesta
ISSUE
Some 2014-2015 Fiesta vehicles equipped with a 1.6L GDTI engine and built on or before 10/7/2014 may exhibit a
concern where the Oil Change Message cannot be reset.
ACTION
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 92.02 or higher. Make sure
you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may
also be obtained at Motorcraft Technical Resource.
How many others have experienced this? I don't want to have to wait for this thing to actually tell me that I need to change my oil in order to reset the oil life, and I sure don't want my vehicle health reports showing the incorrect oil life remaining. When I change the oil, I want the counter to be reset.
Ideas [MENTION=582]FordService[/MENTION] ? Am I going to have to schedule a trip to my dealer to get my PCM reprogrammed? My build date is 08/14, so within the time frame the TSB states.
TSB 14-0202
FORD:
2014-2015 Fiesta
ISSUE
ACTION
