Yeah i am doing research too. I will pull the trigger on a kit this week and install next week. I will document as well
Hey, so I've ordered the Racerpartswholesale kit and now I need two parts besides the brackets which are easy to fab, and the m8 and m6 nuts / lock nuts to attach.
1.A hex pipe nipple to connect the mocal thermostats center pipe to the engine, about 1 3/4" to 2.5" long male to male 3/4"x 16 threads. I cannot find one in these threads, we absolutely need this to get rid of the liquid-liquid cooler. I'm not going to take the stock exchanger off until I go to do the job, so I was going to order a couple sizes of the hex nipple
Something like this:
So when attached to the mocal unit, it would look like Mishimotos center bolt:
This is where the mishimoto kit differs, because its sandwich plates center bolt is much longer then the mocal unit and has male threads to screw into the engine. I'm wondering if we can use the stock one in place of the mocal one, or if the stock one will be too long...
Watch from 5:48 to see the old center bolt and the mishimoto center bolt. We need the threaded pipe with the hex head to extend the mocal center bolt. Screw it onto the engine, then screw the mocal unit onto that.
https://youtu.be/pSvEwQugFdA?t=5m48s
2.A connector for the hoses from the liquid to liquid exchange. I need to figure out the diameter of outlets on the cooler and this part is easy to find. Does anyone know the diameter of the stock outlets on the liquid to liquid exchange?
$17 bucks from here but can be found cheaper elswhere or find a pipe of this diameter to use.
http://www.speedwaymotors.com/Aluminum-90-Degree-Hose-Connectors,49595.html
EDIT: I emailed mishimoto asking if they would sell their center bolt. Will update
[MENTION=1848]mishimoto[/MENTION] would you guys sell your center bolt?
