Offside driveshaft setup
meddylad
Wales
Hi all..,, so today i have managed to round off the O/S bolt that passes through the disc pads to be secured by a 32mm nut. I justcwant to know if just the short part can bupe purchased, or is a complete kit needed?
Or I will grind down some of the worn threads as there are 4 or 5 undamaged threads at the bottom which should be enough to get a good grip, although it rarely gets tested as the driveshaft stays put in the spindle pretty well
