Looking to swap transmissions soon with my Wavetrac LSD unit. While I am in there I would like to replace the OEM clutch and auxiliary components that fall under the "while you're in there" category. I searched for a similar thread to no availability.
Do I have the right part numbers? Have I missed anything you would replace if you were in there?
Clutch & Pressure Plate: C1BZ-7B546-J
Flywheel: C1BZ-6477-B (Can my stock unit be resurfaced?) Should I replace after 80k miles or reuse?
Slave Cylinder: DG9Z-7A564-B (appears to include throw out bearing?)
LSD Specific
Diff Installation Kit: M-4026-FA (includes new axle seals, diff bearings, and ring gear bolts)
Instructions: https://performanceparts.ford.com/download/instructionsheets/FORDINSTSHTM-4026-FA.PDF
Have I missed anything?
LSD Specific
