I've just had to replace mine at 66,000 miles. While I tend to drive the car hard sometimes, I'm never abusive. It had been clicking at idle for several thousand miles and finally let go. I've never worn out a clutch in car with less than 140,000 miles.
The symptoms were odd. (The streets had been full of water the day before I had problems. I tried not to go thru anything that would touch the bottom of the car, but I had to get home soooo... maybe it did. But I digress). The next day the clutch pedal was low, only about 1/2 way up. I noticed that it was slipping on some shifts. I limped it home without stopping (I only had to run two STOP signs). I tried starting and stopping the engine to make sure that I could disengage the clutch and that the car would still start. I came out the next morning and the pedal was to the floor. It had simply sunk down during the night!. I pulled it up with my hand, started the car and everything was fine. Odd. I assumed that the problem was in the slave cylinder and took the car to the local mechanic. (My local Ford dealer is a piece of crap to whom I will never again take a car. I have my servicing done an hour away in Portland). They told me the clutch needed to be replaced. In order to access the slave cylinder they have to take out the tranny and if you're going that far it's silly NOT to replace the clutch while you're there anyway. I agree.
The flywheel was slightly scored with definite burn marks and ----I don't know the name but it the facing loose on the flywheel. That was the rattling I've been hearing as the noise it gone at idle in neutral. This is probably what caused the clutch to wear prematurely. They replaced the slave of course but found no leakage indications., which seems odd given the symptoms. All good now.
My 2¢
My 2¢
